igHunterKiller
May 17, 2021Aspirant
C6300 Port Forwarding not working
I am struggling to make port forwarding happen. Please find attached a png that is a set of screenshots of what I have set up. What did I get wrong? I have a static IP configured for the server (it...
- May 30, 2021
Ah thanks for the keyword 'loopback'. I did the test with the external IP and it wasn't working. So I tried a different game just to be extra-sure, and that worked. What's different? I guessed it was maybe 'Java' for Minecraft. 'java' and 'loopback' led me to some ineffective things to change, but then I came across this one:
https://www.youtube.com/watch?v=DAEkA2LEyb8
There's more than a few Java-related items that Windows firewall blocks, so enabling them all got things working again.
Thanks for walking me through the elimination testing - that keyword of 'loopback' sparked me down a path I had not gone down deep enough.
antinode
May 29, 2021Guru
Your WAN/Internet IP address is a valid public address, which covers
usual problem 1.
Your port-forwarding rule 8 and address reservation seem plausible,
which covers usual problem 2.
That connection log seems to show the desired port forwarding.
> You seem to have 2 and half of 3 covered.
Still true.
> [...] the games I am attempting to enable see LAN clients connect
> successfully, and WAN clients cannot. [...]
Eh? You lost me. There are two tests for problem 3. The first is:
Can you access the server from a system on your LAN using the
server's LAN IP address? [...]
That is, from a system on your LAN, can you access the (game) server
at "192.168.0.10:25565"? Success there proves that the (game) server is
listening on that port at that address.
The second test for problem 3 is:
router's WAN/Internet IP address ("172.117.a.b:25565")?
Success there proves that port forwarding and NAT loopback (on the
router) are working.
The final test is like the second one, but from a system in the
outside world. If both internal tests work, but the test from the
outside world fails, then I'd tend to blame the ISP.
igHunterKiller
May 30, 2021Aspirant
