EHoelscher
Sep 05, 2016Aspirant
C6300 ReadyShare Drive Time & Date is wrong
I cannot figure out how to get my time on the readyshare files to be correct, they keep resetting to 2000 and I would like the files to be correct...any ideas? Thanks for any help it is appreciat...
DarrenM
Sep 12, 2016Sr. NETGEAR Moderator
Hello EHoelscher
Is this still happening or has it resolved its self?
DarrenM
EHoelscher
Sep 12, 2016Aspirant
Not resolved yet, got any ideas? Thanks! Elisa
- DarrenMSep 14, 2016Sr. NETGEAR Moderator
Hello EHoelscher
If you go to the logs on the modem are you seeing the correct date or is that messed up to?DarrenM
- EHoelscherSep 15, 2016Aspirant
Darren,
I found the logs and they seem fine. All dates and even times seem like what they should be. Somehow my Readyshare never makes it past Jan 2000.
Thanks, Elisa
- DarrenMSep 29, 2016Sr. NETGEAR Moderator
Hello EHoelscher
Does this happen on other drives you connect to readyshare?
DarrenM
