Addy165
Jan 03, 2021Follower
C6300 Reservations not working
My router will not let me set a static IP address for devices.
It worked fine three days ago. Comcast had an outage in our area two days ago. I don’t know if it started the problem or if it is just a coincidence.
I have followed the steps below many times without any luck.
Login to Netgear router
Advanced >> LAN Setup >> Add
When I click add, I get the Updating Settings screen with a full meter bar and then it goes blank after a while. Another issue is when I go to Basic >> Attached Devices, it doesn’t show all of the devices on the network. If I use the Netgear genie from my phone, it shows more devices connected.
I have tried the following methods and the problem is not fixed.
Reboot
Unplug router
Reboot from Comcast website
Factory Reset
Renew Lease
It is my understanding that Comcast controls the firmware so I can’t update it.
This is the firmware information.
C6300 Firmware V3.01.12
Hardware Version V3.0
I am extremely frustrated and would appreciate any help you can offer.
No RepliesBe the first to reply
