Jon8
Mar 19, 2019Aspirant
C6300 Router not working
We have a C6300 cable/wireless router that has been connected, but not used for 1 1/2 years. Today it cannot be recognized on the network.
Hand helds cannot see it, and if we plug into it the comp...
antinode
Mar 19, 2019Guru
There's a forum for those:
https://community.netgear.com/t5/x/bd-p/home-cable-modems-routers
> [...] None of the lights on the front of it are lit, [...]
That's a bad sign. Visit http://netgear.com/support , put in your
model number, and look for Documentation. Get the User Manual. Look
for the LED descriptions and "Troubleshoot".
> [...] but the power source is nominal.
Says who? Determined how? Connecting a voltmeter (only) to a power
adapter is not a rigorous test; you need a realistic load (like, say, an
actual modem+router) for a realistic test.
> [...] When turning the power on and off with the button on the back
> the power light in front flashes red and then goes out. [...]
A bad power adapter could account for that behavior.
> [...] I haven't performed a firmware update yet, [...]
First, DOCSIS cable-TV modem(+router) devices don't allow firmware
updates by users. Second, how would you do that if you can't talk to
the thing?
> [...] has anyone seen this type of behavior in this product?
Not I, but I'd start by replacing (or more realistically testing) the
power adapter. What have you that can put out 12VDC at 3.5A (or close)?
