Sunla
Oct 03, 2022Aspirant
C6300 router USB printing supported?
Hi guys, does the USB printing with ReadySHARE Printer utility is supported on this router model? I tried to install it but my printer is not listed in the Netgear USB Control Center. I assume it is...
- Oct 03, 2022
Yes. if it doesn't mention any USB printer support, that would not be there to work with.
I would look up some USB printer server devices that could work for you.
Oct 03, 2022Guru - Experienced User
I would check the user manual to see if any such feature appears:
https://www.netgear.com/support/product/C6300.aspx#docs
Or check the modems web page for any USB Printing features...
- SunlaOct 03, 2022Aspirant
In the datasheet page I see only lines
READYSHARE® USB ACCESS—Wirelessly access & share USB hard drive via the USB port
the same is in manual, chapter 5 only mentions about connecting USB drive to the router, nothing else.
Should I imply that this model does not support printers? Lack of mentions = lack of support? It would be nice to have a clear list of supported devices, not implications.
- FURRYe38Oct 03, 2022Guru - Experienced User
