Luke82
Jul 26, 2021Aspirant
C6300 SiriusXM not streaming
I have a NETGEAR C6300 WIFI router that have had for 2.5 years now. In the last few months I have noticed that SiriusXM no longer streams from my Grace Digital radio, it just constantly buffers (play...
Luke82
Aug 17, 2021Aspirant
The radio is a wireless device, as mentioned all other internet radio channels work perfectly, the issue only occurs when Sirius XM chanels are selected.
Thanks for the suggestion FURRYe38, I have since tried temporarily disabling WPA on the modem and connecting the radio, the problem remained.
Aug 17, 2021Guru - Experienced User
I presume this maybe an issue with this one device. I'd contact the the Mfr for help and support on this.
I'd also try this out at a different location with a different wifi system to see if problem follows if possible. If it doesn't, then you may need to upgrade the C6300 to something different or use the modem portion of the C6300 and install a exnternal wifi router.
