skbz1999
May 19, 2017Tutor
C6300 Slow Download Speed
C6300 v1.02.21 os: os x sierra, android, windows 10 **Speedtest shows 40.06mbps down and 32.57 up** Pay for 200/20 but Normal 250-750 down & 20-50 up. Procedure Status Comment Acquire Downstream ...
DarrenM
May 26, 2017Sr. NETGEAR Moderator
Hello Skbz1999
Are you seeing any uncorrectables? or anything in the logs?
DarrenM
skbz1999
May 26, 2017Tutor
C6300 V1.02.21
Windows 10, OS X Sierra
Called Suddenlink and they got speed back to normal but of course within 6 hours was getting lag again.
| 1 | Locked | QAM 256 | 12 | 627000000 Hz | 5.6 dBmV | 38.9 dB | 3748 | 71925 |
| 2 | Locked | QAM 256 | 16 | 651000000 Hz | 6.1 dBmV | 40.3 dB | 5473 | 58002 |
| 3 | Locked | QAM 256 | 17 | 657000000 Hz | 6.1 dBmV | 38.9 dB | 6627 | 83866 |
| 4 | Locked | QAM 256 | 18 | 663000000 Hz | 6.1 dBmV | 38.9 dB | 4656 | 54515 |
| 5 | Locked | QAM 256 | 21 | 681000000 Hz | 6.3 dBmV | 40.9 dB | 128820 | 233748 |
| 6 | Locked | QAM 256 | 22 | 687000000 Hz | 6.1 dBmV | 38.9 dB | 4607 | 70004 |
| 7 | Locked | QAM 256 | 23 | 693000000 Hz | 6.3 dBmV | 40.3 dB | 5404 | 83956 |
| 8 | Locked | QAM 256 | 24 | 699000000 Hz | 6.0 dBmV | 40.9 dB | 8252 | 63598 |
| 9 | Locked | QAM 256 | 25 | 705000000 Hz | 5.9 dBmV | 40.3 dB | 8370 | 82694 |
| 10 | Locked | QAM 256 | 26 | 711000000 Hz | 5.8 dBmV | 38.9 dB | 7714 | 94914 |
| 11 | Locked | QAM 256 | 27 | 717000000 Hz | 5.9 dBmV | 38.9 dB | 7467 | 80357 |
| 12 | Locked | QAM 256 | 28 | 723000000 Hz | 5.5 dBmV | 38.9 dB | 6243 | 56782 |
| 13 | Locked | QAM 256 | 29 | 729000000 Hz | 5.8 dBmV | 38.9 dB | 7520 | 64206 |
| 14 | Locked | QAM 256 | 30 | 735000000 Hz | 5.6 dBmV | 38.6 dB | 7555 | 65621 |
| 15 | Locked | QAM 256 | 31 | 741000000 Hz | 5.8 dBmV | 38.6 dB | 6728 | 88038 |
| 16 | Locked | QAM 256 | 32 | 747000000 Hz | 5.5 dBmV | 38.9 dB | 5516 | 71400 |
| May 17 01:41:56 2017 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| May 17 13:59:21 2017 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| May 17 13:59:26 2017 | Warning (5) | Lost MDD Timeout |
| May 17 13:59:44 2017 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| May 18 13:41:54 2017 | Notice (6) | DHCP Renew - lease parameters tftp file-^1/53C06468/TYPE=RES/COS=186/IP=1 modified |
| May 22 13:43:31 2017 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| May 22 13:43:37 2017 | Warning (5) | Lost MDD Timeout |
| May 22 13:45:03 2017 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| May 22 13:45:09 2017 | Warning (5) | Lost MDD Timeout |
| May 22 14:32:47 2017 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| May 22 14:32:53 2017 | Warning (5) | Lost MDD Timeout |
| May 22 14:33:03 2017 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| May 22 14:33:09 2017 | Warning (5) | Lost MDD Timeout |
| May 22 14:33:13 2017 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| May 22 14:33:50 2017 | Warning (5) | Lost MDD Timeout |
| May 22 14:33:56 2017 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| May 22 14:34:17 2017 | Warning (5) | Lost MDD Timeout |
| May 22 14:34:23 2017 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| May 23 01:41:54 2017 | Notice (6) | DHCP Renew - lease parameters tftp file-^1/4636C4E9/TYPE=RES/COS=186/IP=1 modified |
| May 23 13:53:27 2017 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| May 23 13:53:33 2017 | Warning (5) | Lost MDD Timeout |
| May 23 13:53:53 2017 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| May 23 13:53:59 2017 | Warning (5) | Lost MDD Timeout |
| May 23 15:41:52 2017 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| May 23 15:41:56 2017 | Warning (5) | Lost MDD Timeout |
| May 23 15:42:06 2017 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| May 23 22:09:58 2017 | Critical (3) | No Ranging Response received - T3 time-out |
| May 24 13:41:55 2017 | Notice (6) | DHCP Renew - lease parameters tftp file-^1/AD4275D6/TYPE=RES/COS=186/IP=1 modified |
| May 24 15:55:32 2017 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| May 24 15:55:37 2017 | Warning (5) | Lost MDD Timeout |
| May 24 15:56:37 2017 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| May 24 15:56:43 2017 | Warning (5) | Lost MDD Timeout |
| May 24 15:56:57 2017 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| May 24 15:57:03 2017 | Warning (5) | Lost MDD Timeout |
| May 24 15:57:06 2017 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| May 24 16:00:28 2017 | Warning (5) | Lost MDD Timeout |
| May 24 16:00:38 2017 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| May 24 16:00:43 2017 | Warning (5) | Lost MDD Timeout |
| May 26 01:41:55 2017 | Notice (6) | DHCP Renew - lease parameters tftp file-^1/B8C91608/TYPE=RES/COS=186/IP=1 modified |
| May 26 08:32:39 2017 | Critical (3) | No Ranging Response received - T3 time-out |
- DarrenMMay 30, 2017Sr. NETGEAR Moderator
Yea I do see alot of uncorrectables on all the channels you may want to have the ISP check the lines.
DarrenM
