restored123
Dec 23, 2020Tutor
C6300 slow internet (xfinity internet)
Hey everyone, I've been having off and on slow internet for about a week now. Here some notes on what I've done so far: -There was a splitter from where the cable wire came out of the wall to...
restored123
Dec 23, 2020Tutor
"Are your speeds wired? or wireless?
How are you testing them? via app? built in speedtest? the actual speedtest website? Details are key here."
Thanks for the reply. So I'm testing on both wired and wireless. I do a lot of gaming and notice significant drop off in performance as well.
I've used both speedtest.net as well as Xfinity's speedtest website.
Right now the internet speed is fine but I notice that it will drop off to around 30-50 MBPS at different times. Just not sure why it drops at different points.
Dec 23, 2020Guru - Experienced User
@restore
Right now the internet speed is fine but I notice that it will drop off to around 30-50 MBPS at different times. Just not sure why it drops at different points.---could be something stupid like wind blowing a coax line. I had things like that cause signals to be good then bad. its tough to pinpoint when it only happens occasionally.
do you get full speed wired?
The cable connections page just takes the info from that moment in time you load the screen. Pull that cable connections page when the speeds drop.
Also, the event logs show us a longer period of time. Such as dynamic power violations (power goes in/out of spec) t3/t4 errors. which is why we'd like those :)
- restored123Dec 23, 2020Tutor
plemans wrote:
@restoreRight now the internet speed is fine but I notice that it will drop off to around 30-50 MBPS at different times. Just not sure why it drops at different points.---could be something stupid like wind blowing a coax line. I had things like that cause signals to be good then bad. its tough to pinpoint when it only happens occasionally.
Okay, i'll be sure to pull the cable connections when the speed drops and post it.
Here is the event logs. Sorry didn't realize this was what you wanted originally:
Dec 23 2020 11:09:53 Critical (3) No Ranging Response received - T3 time-out Dec 23 2020 08:56:58 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Dec 22 2020 14:27:45 Warning (5) Lost MDD Timeout Dec 22 2020 14:26:52 Error (4) Service Add Ack rejected - Invalid transaction ID Dec 22 2020 14:26:35 Warning (5) Lost MDD Timeout Dec 22 2020 14:25:59 Error (4) Service Change Response rejected - Invalid transaction ID Dec 22 2020 14:18:50 Warning (5) Lost MDD Timeout Dec 22 2020 13:58:35 Error (4) Service Change Response rejected - Invalid transaction ID Dec 22 2020 13:12:41 Warning (5) Lost MDD Timeout Dec 22 2020 13:09:22 Error (4) Service Change Response rejected - Invalid transaction ID Dec 22 2020 12:16:25 Warning (5) Lost MDD Timeout Dec 22 2020 12:16:14 Critical (3) No Ranging Response received - T3 time-out Dec 22 2020 11:56:39 Warning (5) Lost MDD Timeout Dec 22 2020 11:56:33 Error (4) Service Add Ack rejected - Invalid transaction ID Dec 22 2020 11:45:30 Warning (5) Lost MDD Timeout Dec 22 2020 11:45:26 Error (4) Service Change Response rejected - Invalid transaction ID Dec 22 2020 11:45:10 Warning (5) Lost MDD Timeout Dec 22 2020 11:45:06 Error (4) DCC-ACK rejected authentication failure Dec 22 2020 11:09:19 Warning (5) Lost MDD Timeout Dec 22 2020 11:09:04 Error (4) Service Change Response rejected - Invalid transaction ID Dec 22 2020 11:00:05 Warning (5) Lost MDD Timeout Dec 22 2020 10:59:54 Error (4) Service Change Response rejected - Invalid transaction ID Dec 22 2020 10:46:24 Warning (5) Lost MDD Timeout Dec 22 2020 10:46:19 Error (4) Service Change Response rejected - Invalid transaction ID Dec 22 2020 10:30:35 Warning (5) Lost MDD Timeout Dec 22 2020 10:30:28 Error (4) Service Change Response rejected - Invalid transaction ID Dec 22 2020 10:20:34 Warning (5) Lost MDD Timeout Dec 22 2020 10:20:12 Error (4) Service Change Response rejected - Invalid transaction ID Dec 22 2020 10:14:52 Warning (5) Lost MDD Timeout Dec 22 2020 10:14:51 Error (4) Service Change Response rejected - Invalid transaction ID Dec 22 2020 10:12:54 Warning (5) Lost MDD Timeout Dec 22 2020 10:12:47 Error (4) Service Change Response rejected - Invalid transaction ID Dec 22 2020 09:53:54 Warning (5) Lost MDD Timeout Dec 22 2020 09:53:48 Error (4) Service Change Response rejected - Invalid transaction ID Dec 22 2020 09:34:26 Warning (5) Lost MDD Timeout Dec 22 2020 09:34:26 Error (4) Service Change Response rejected - Invalid transaction ID Dec 22 2020 09:27:43 Warning (5) Lost MDD Timeout Dec 22 2020 09:27:05 Error (4) Service Change Response rejected - Invalid transaction ID Dec 22 2020 09:20:15 Warning (5) Lost MDD Timeout Dec 22 2020 09:20:04 Error (4) DCC rejected authentication failure Dec 22 2020 09:20:04 Error (4) DCC rejected authentication failure
