AlbertoL
May 09, 2022Follower
C6300 some devices connect only to guest wifi
All older devices that I have purchased before 2013 can connect to both main Wifi and guest Wifi networks (OS currently in use on those devices are Ubuntu 20.04, Windows 7 and Windows 10). All more r...
May 09, 2022Guru - Experienced User
Does it connect if you remove the password from the wifi?
Make sure there's no special characters or spaces in the ssid or password
