StuartW1982
Nov 24, 2016Aspirant
C6300 stops connecting new devices
Firmware: V2.01.14 After a factory reset, ssid change and password change the first handful of devices connect just fine and they stay connected. However, any device that tries to connect later cann...
hawki
Nov 25, 2016Apprentice
I am having a similar issue with my C6300 - posted above today - 11/25/2016
My issue arose after just changing my PW. I did not do a factory reset.
Very frustrating problem - not being able to connect devices , e.g., phones, printer to my network.
- DarrenMNov 29, 2016Sr. NETGEAR Moderator
Hello hawki
On the device that is having issues have you told it to forget the network and they try to connect again?
DarrenM
- StuartW1982Mar 06, 2017Aspirant
It's happening again. If I reboot the router there is like a 3 minute period where devices can connect. After that all other devices get shut out - they connect but with no internet. If you "forget" the network and try to reconnect you still don't get internet. The devices that are connected don't have any problems except if they log into the router the router's setup pages won't load.
- DarrenMMar 08, 2017Sr. NETGEAR Moderator
Has any reboot worked or is it doing this every day?
DarrenM
