hklo's avatar
hklo
Tutor
Aug 18, 2021
C6300 v2, port 22 blocked while in DMZ
Cable modem with wifi router model C6300 v2 firmware v1.03.06. IP version 6 firewall disabled.
Tested from outside that port forwarding of 22 and 80 works OK when set up through port forwarding.
Remove all port forwarding and put machine into DMZ. Port 80 is still accessible and port 22 can not be accessed.
Netgear tech support told me this is a known issue that a device inside DMZ has some ports blocked. This is a fake DMZ if it is not wide-open! What is the list of ports blocked while in DMZ, and is this list in some product documentation?
Also, is there a IP version 4 firewall and where can it be found in the (slow) router web interface? There is a IP version 6 setting and it can be disabled.
  • FURRYe38's avatar
    Something to ask NG to see if there going to fix. If not, then you might want to configure the modem for modem mode only and then connect a external wifi router that has a better DMZ feature.
    Review the user manual for modem features that are included on the modem. Most firewalls are automatic and no seen. Using Port Forwarding or Triggering will configure ports when need thru the firewall.
    Good Luck.
    • hklo's avatar
      hklo
      Tutor
      Tech support now says ports 22 and 23 are blocked while in DMZ. They claim all other ports are open. From my standpoint, this blocking was done on purpose so I suspect it will not be fixed.
      This should at least be in the product documentation, as people make the assumption that DMZ opens all ports. Somewhere is a Netgear product manager who should be doing some 'splaining.
      I suppose I will remap ssh to a different port. This is non-standard, so it will cause doc and usage hassles for me and my friends.
      • FURRYe38's avatar
        I recommened changing the modem to modem mode and finding a external router that you can use and has better DMZ support.
        Good Luck.
