johnlf
Dec 05, 2023Follower
C6300-V2 wired ethernet connection works but wifi quit working
I get cable signal and internet using wired connection but wifi quit working. Checked all my settings and all is good. Haven't even had this a year yet. I had a previous one, same model and it did th...
Dec 06, 2023Guru - Experienced User
Does the front WiFi LEDs turn OFF when this happens?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 64. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed?
This C6300 series is of older generation and maybe no longer supported. You might consider getting into a separate ISP cable modem only unit then connect up a separate external connected wifi router system.
