Staile
Jul 23, 2016Aspirant
C6300 WAN DHCP Lease
Hello, I'm experiencing an odd issue with my C6300 modem router. If the unit looses power or is rebooted I can no longer connect to the Internet. It appears that the WAN port (incoming coax) does not...
Staile
In case it helps this is what the internet port section looks like when it isn't working. I've removed the MAC address line
Internet Port
MAC address
IP Address/Mask ---.---.---.---/-
Connection DHCP Client
Default Gateway ---.---.---.---
Domain Name Server ---.---.---.---
Internet Port
MAC address
VE6CGX
Jul 23, 2016Master
If you reset, you need to configure the router again or restore saved config file. Tried just rebooting>
