bootsBslick79
Apr 12, 2020Follower
C6300 wifi drops but ethernet works
C6300 over a year old loses wifi but ethernet ports seem to work. If I reset router/modem the wifi will work with multiple devices then after approximately 10 mins or less it's gone yet anything plugged into the ethernet works fine. HELP!!!!
1 Reply
Any Wifi Neighbors near by? If so, how many?Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
