Notimpossible
Nov 30, 2015Tutor
C6300 wifi drops
Good morning, Yesterday my C6300 wifi signal stopped working. I bought this router a year and a month ago so my warranty is gone. I have tried rebooting and a factory reset from the Gen...
vkdelta
Nov 30, 2015NETGEAR Employee Retired
can you please try factory defaulting the router to see if problem goes away?
can you please PM me if you still see the problem? I would like to work with you.
Notimpossible
Nov 30, 2015Tutor
vkdelta, I have factory defaulted the router several times as well as rebooted the router several other times. I have decreased my MTU from the default 1500 bytes down to 1440 as this was the only setting that passed a ping test. I don't know if I have a device that is causing this because the only thing that changed recently is that I bought a new cell phone. Shortly after I brought that device home I started having issues.
- vkdeltaNov 30, 2015NETGEAR Employee Retired
which Cellphone did you get?
- NotimpossibleNov 30, 2015Tutor
Microsoft Lumia 950
- winboyDec 15, 2015Tutor
I also have the same problem with the device. I just upgraded my phone to a Microsoft Lumia 950 XL. Is there a solution? I bought my device just under a year ago.
- NotimpossibleDec 20, 2015Tutor
I think it may have something to do with a Lumia setting. I returned my phone and the problem is gone.
