Mani
Nov 10, 2015Aspirant
c6300 wifi problems
Hello there, I got the C6300 in May and I'm starting to have problems with the wifi connection. The internet speed is very slow using Wifi and I can only connect to the 2.4Ghz Wifi connection. ...
DarrenM
Nov 12, 2015Sr. NETGEAR Moderator
Hello Mani
Have you tried a factory reset to see if the 5Ghz will come back on? also you may want to contact your cable provder and talk to there tech support make sure everything looks good on there side because I know sometimes they have to enter a wifi code into there billing system to send a signal to the modem to allow the wifi to work properly. Hope to hear your feedback.
DarrenM
