maceman121
Oct 01, 2016Aspirant
C6300 Wireless disappearing on me (2.4 and 5)
So, my router was working great for the first two weeks, but as of the other day, interesting, and annoying, issue arose. My wireless suddenly, and without logical reasoning, stops transmitting. Th...
maceman121
Also, on the home screen of log in to the router, it says wifi is off. So likely the issue, even with lights on, but at the same time, no idea how to turn it on remotely, nor why its shutting off at all. At least it did for a bit, now it says its on again, but still nto transmitting anything until Ireboot it, only to fail again.
When I look at each wireless transmission, it says they are both Currently: 0, for the current channel, even though on drop down I select, and updated, to an actual channel.
- DarrenMOct 04, 2016Sr. NETGEAR Moderator
Hello maceman121
I would suggest contacting Netgear support if your modem is still under warranty it could be a hardware issue.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
