jtrading
Apr 11, 2017Follower
C6300 Wireless Network shows up for a few seconds, then disappears when connected
Netgear C6300 Ethernet connection works fine Wireless 2.4/5GHz are both transmitting (LEDs solid green). When I reboot/reset, the SSID networks will both show up initially. When my computer c...
finest14
Jul 17, 2017Aspirant
I have the exact same issue. The router has worked fine for one year connected to various Apple products, a smart TV, a PS3 and a Dell PC running Windows 10 with a Dell wireless card. Tried to connect a new Lenovo PC running Windows 10 with a Qualcomm wireless card and my networks disappear. Unfortunately, the moderators suggestion to contact support doesn't help me because I don't want to pay for support.
- DarrenMJul 20, 2017Sr. NETGEAR Moderator
Hello finest14
Does the networks disappear for all devices or just the one?
DarrenM
- finest14Jul 20, 2017Aspirant
Just the one. PC with a Qualcom wireless adaptor. Our Apple devices, smart TV, PS3 and Dell PC all work. Took the other PC back to the store and exchanged it for a different brand and it works fine. Not sure what the conflict was between the Netgear and Qualcom was.
- MarceloLucaAug 01, 2017Aspirant
DarrenM,
My router is experiencing the same issue, when I turn my Lenovo Yoga 710 on, the router craches and I need to reboot it. It just hapen with this computer(lenovo) all other phones tablets and computers work fine, and the Lenovo work fine on other routers.
Do you think updating the firmware helps?
