rwph
Aug 20, 2017Aspirant
C6300 Wireless stops working
My C6300 firmware v2.01.18 using Windows 10 and 8.1 same problem with all computers, no matter location, wireless stops working, drops out or doesn't work after a factory reset or reboot. Sometimes it works just fine and then stops and goes away. Thanks for any advice.
- DarrenMSr. NETGEAR Moderator
Hello rwph
Have you tried to change the wireless channel on the modem?
DarrenM
- ParanoidPharaohAspirant
Mine is doiong the same thing. I tried changing the channnels, disabaling one of the radios. It sometimes works if I hard boot it. Support is not very good for this product.
