cwh1947
Jun 01, 2019Aspirant
C6300 WPS process succeeds but no client shown in attached devices
while attempting to attach a dlink camera using WPS the process is done as follows: I push the softwre button in the wps wizard, then go to the cam and push the client wps button. The router displ...
- Jun 01, 2019
I did a total reboot of modem/router and all is ok now.
WPS working as it should. Thanks for suggestions
Jun 01, 2019Guru - Experienced User
Try to set up the cameras via wired connection with the wireless ssid and PW.
