Straw
Mar 23, 2016Aspirant
C6300
Wi-Fi works fine but like to directly hook up to my Netflix. Will find Wi-Fi on my smart tv but fails to hardwire using my ethernet
- DarrenMSr. NETGEAR Moderator
Hello Straw
So the smart Tv can not connect to the internet via Ethernet?
DarrenM
- StrawAspirantNo
Hello Straw
Have you tried to go into the network settings of the Smart Tv and try to manually enter the Ip info with the ethernet plugged into the tv something like 192.168.0.25 for the ip and the default gateway as 192.168.0.1
DarrenM
- StrawAspirantI'll try...thanks
- gummieAspirant
I am having same problem did this work for you?
- StrawAspirantNo it didn't...still using WiFi...no one seems to have an answer
