jchris92490
May 24, 2018Aspirant
C6300
Im currently havung problems connecting to a server... My internet provider said everything is great on their side . but nothing seems to connect to a server. Everytime i try to log in to the router log in it says the ip address is unavailable or the dns server is not found anyone that can help????
I have tried resetting it manually.. Also removed the coax cable power cablre etc. And nothing seems to work .
- Erodriguez3562InitiateI’m having the same problem
- jchris92490Aspirant
i dont know if this will help you, i resetted i using the toothpick to pick at the little hole in the back that says "reset" and well i did it twice and it started working. Hopefully it stays working
- Erodriguez3562InitiateI will have to give it another try hopefully it works for me
