bmalik
Jun 28, 2020Follower
C6300
WIll the AC1750 Wi-Fi Cable Modem Router Work with the NETGEAR - Nighthawk Mesh X6S Tri-Band WiFi Mesh Extender ?
Thanks in Advance
Bmalik
Possible, though you may want to try a EX3700 or a EX7000 model extender.
I'd stick with the tribands.
Much better performance.
The standard dual band (not in fastlane) take a roughly 50% speed hit because they have to receive and then retransmit and can't do both at once.
And a triband extender should work with that router. I've used my EX8000 on a C7000, C7800, and CAX80
