LFred's avatar
LFred
Follower
Sep 06, 2022
C6300
Keeps dropping wifi
  • michaelkenward's avatar
    michaelkenward
    LFred wrote:
    Keeps dropping wifi
    That's a shame. But what does it mean? What happens?
    Tell us more.
    You can help people to help you by providing the information suggested in this forum's header:
    Subject (Include model number and brief summary)
    Model (Recommended - Helps the community give the best answers)
    Body (Include additional detail including model version, firmware, OS and environment where relevant.)
    They are there for a good reason.
  • plemans's avatar
    Is it only wifi dropping? or do wired devices drop as well?
    Have you noticed if its both wifi channels or just 2.4gh or 5ghz?
    When it "drops", what actually happens? Do devices say "connected, no internet", do they disconnect from the wifi and not rejoin, does the wifi stop broadcasting entirely?
    Details are key. the more you can tell us, the more we can help you.
    Also, do you have a screen snip of the cable connections page and event logs? that helps check your isp line
