AMASMELA
Aug 30, 2021Follower
C6300v2 2.4 GHz network is not available
my cable modem model is C6300v2. the problem is that only 5G MHz network is shown as available to connet the WIFI, but to2.4 MHz network isnot available shown.
it syart happenning 2 days ago. i have some devices that only work with 2.4MHz
1 Reply
what have you done to try and fix it?
Reboot?
Factory reset?
disable/enable wifi ssid?
turn wifi on/off on the hardwired button?
