Oregeki
Jun 15, 2020Follower
C6300v2 2.4ghz not connecting
OK so on 6/14/20 our Iphone's, ps4, old windows 7 laptop, nintendo switch, etc any devices that werent directly connected to the router stopped showing the 2.4 ghz connection. It had been showing for...
SFields
Nov 29, 2020Aspirant
Did you ever figure this out?
I am having the same issue. The 5G connection is showing but not the 2.4. I have done on the sets that you show you did also. Still nothing. I have some devices that do not connect to 5G so I need the 2.4.
Thank you for any reply.
wcalifas
Nov 29, 2020Prodigy
You can also try updating the firmware or reloading it and see if it revives the 2.4gzh band.
- antinodeNov 29, 2020Guru
> revives the 2.4gzh band.How, exactly, do you propose that the user should do that with a
DOCSIS modem+router?
