JoJo27
Aug 09, 2022Guide
C6300v2 AC1750 Comcast claims it's incompatible
Comcast is now claiming our wifi router is incompatible with our current internet plan ("incompatible based on filters," whatever that means). Such that we aren't taking full advantage of our internet...
- Aug 10, 2022
The 369mbps is more realistic for that device on comcast. You might hit a bit faster but you don't really use it over wifi.
I'd look into seeing if there's a cheaper plan around that 200-300mbps for your device.
JoJo27
Aug 09, 2022Guide
It sounds like you're saying our device should be able to keep up despite what CC claims. When my ISP no longer supports my device, will I then experience a disruption in my service? Is that how I know? The netgear website says my model is supported by CC, or works with it
JoJo27
Aug 09, 2022Guide
Just to clarify, my internet plan with CC IS
"Downloads up to 600
Uploads up to 20"
Not my device (listed in the subject)
Uploads up to 20"
