paphaba
Feb 06, 2021Aspirant
C6300v2 Access Control Not Working
Model: C6300v2 Firmware v1.03.06 Then I go into Access Control with the Netgear Genie all the connected devices are allowed. No matter that I do (check items, push allow button, push block butt...
michaelkenward
Feb 07, 2021Guru - Experienced User
You refer to the genie. This could be one of several things, the browser interface, a Windows or Mac program for a PC, or a mobile Android/iThing app. Netgear labels them all as genies. Which are you using?
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routers
I will ask the Netgear moderator to move your message.
paphaba
Feb 07, 2021Aspirant
I am using Windows 10 on a laptop. It does not work with the Firefox or Microsoft Edge browsers. The Genie software is not installed on the laptop. It is in the Modem/Router and is accessed by typing the IP address in the browser. I searched access control in the community and found nothing helpful.
