Wifi-Bri
Oct 05, 2022Follower
C6300v2 Browsing Latency issue on Sprectrum
I've had this model for about 2 weeks and since then browsing the internet has become a pain. It takes anywhere from 10-30 seconds to fully load the page. There is some variance here which depends on how much data is on the page and if it's been cached, but I previously didn't have this problem. It generally loaded pages immediately prior to owning this modem/router. Running a speed test on the spectrum site does not reveal any issues: 117 mbps download /11.7 mbps upload. Pretty consistent with what I had before this modem. Does anyone know where to start looking to find the root cause of this problem?
Thanks
Brian
1 Reply
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-routerHave the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.htmlIs this with a wired and wireless devices?
What browser are you using? Happens with other browsers?
