ymukh2000
Sep 30, 2024Aspirant
C6300v2, downstream on but upstream flashing,no connection
Looking for help with my router, we had an Xfinity outage earlier today and the router went from working with occasional interruptions to connecting while saying there's no internet. Mousing over the ...
Oct 01, 2024Guru - Experienced User
got a copy of the cable connections page?
That helps check the connection back to xfninity
And if they were messing with the lines and this all started afterwards, tends to point at the ISP.
ymukh2000
Oct 01, 2024Aspirant
- plemansOct 02, 2024Guru - Experienced User
it looks like line isssues.
to do your best to prevent them from charging you for a visit: start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
