MATiX
Apr 11, 2022Follower
C6300v2 firmware out of date
I have had Netgear modem /wireless router for couple years. The android phone Nighthawk app have never worked for me. I am having a lot of interruptions with my internet. I know that my current ISP (W...
Apr 12, 2022Guru - Experienced User
michaelkenward has answered the firmware issue.
Do you have a copy of the cable connections page and the event logs?
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
