Retired_Member
Jul 21, 2021C6300v2 has lots of critical errors
Hi Just bought a new C6300v2/AC1750 3 days ago. It has a lot of critical errors already. Here is an example. Should I return this modem? It's only 3 days old and already has issues. Thanks. Ba...
- Retired_MemberJul 25, 2021
SOLVED. It wasn't the new Netgear modem/router. It was Spectrum. They came out on Friday and ran a new line from the pole to my house and got rid of all the splitters in the box outside and it's working perfectly. Not a single error in 2 days.
Barbara
Jul 21, 2021Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://highspeed.tips/docsis-events/
Barbara
- FURRYe38Jul 25, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Enjoy. :smileywink:
