Calebscottr
Dec 11, 2021Aspirant
C6300v2 Wifi SSID no longer showing
Hi, recently the power flickered and I have experienced a problem where I am no longer able to connect to my wifi on any device. I have called both my ISP and Netgear, which have said there aren't any...
Dec 11, 2021Guru - Experienced User
Have you logged into the router and checked its ssid/password setup?
You can hardwire a device into it to connect/access it.
- CalebscottrDec 11, 2021AspirantHi, yep I've hardwired into it and there doesn't seem to be anything beyond the default there. The SSID is being broadcasted and it is all default name and password.
- plemansDec 11, 2021Guru - Experienced User
Is it showing enabled?
What are the wifi led's on the front of the router showing?
Have you done a wireless scan?
Or pushed and hold the wifi on/off button for 2 seconds?
- CalebscottrDec 11, 2021AspirantYep it is showing enabled. All of the lights are showing green, and I have tried holding down the button and resetting the router. I'm not positive what a wireless scan is though
