NightBirdWatch
Jun 05, 2020Follower
C6300v2 wired connection stopped working twice.
Hello. I have had my C6300v2 for a few weeks, and yesterday suddenly my wired connection to the internet went out. All wireless devices could still connect fine. The light on the back of the router f...
Jun 06, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
