BKhoo's avatar
BKhoo
C6900 2.4G SSID Disappeared
My wireless devices all of a sudden can't see the SSID of the 2.4G channel of my router.  The 5G channel is still visible.  I've had this router for probably 2 years and have been using the 2.4G chan...
  • plemans's avatar
    Aug 29, 2020
    Have you logged into the router to see if the 2.4ghz ssid broadcast was disabled?
    Or even just tried a factory reset and reinstall? I'd normally tell you to reinstall the firmware but with combo devices, the isp controls the firmware.
