Bturchi1
May 26, 2020Guide
C6900 connection issues
Hello, because of this coronavirus I have been working from home, occasionally I will lose connection to the internet. The problem as far as I can figure is my up stream. The attached photo is a scree...
May 27, 2020Guru - Experienced User
both your downstream has to many errors and your upstream isn't locking and is to high on power.
try removing any splitters, attenuators, or amplifiers from your line. preferablly hook the modem to right where the coax enters the home without anything in your line.
Then use it for a bit and re-run the cable connections page.
If it isn't any better, then your isp needs to check your line.
Bturchi1
May 27, 2020Guide
Thank you
