fatherofthr33
Jul 26, 2020Aspirant
C6900 Modem Mode for Google Wifi
I recenly purchased the Google Wifi system but it doesn't have any ether ports on the hub. Should I just use the ports on the modem after setting it into Router only mode or do I need to go out and...
Jul 27, 2020Guru - Experienced User
Sonmething to ask Google about. Check the user manual for there product.
If it has a built in router already, you may want to put the C series modem in to modem only mode. As it already has built in router and wifi.
- fatherofthr33Aug 03, 2020AspirantI ended up setting everything up yesterday and the ports on the C series no longer function after putting it into modem mode so I had to go out and buy a switch.
- FURRYe38Aug 03, 2020Guru - Experienced User
Yes that is by design.
So you'll need to put a switch behind the Google router if more ports are needed.
Good Luck.
