pooruser
Mar 23, 2022Aspirant
C6900 Router continuously asking for admin password reset
Rebooted the C6900 router, and now on all devices that connect through wifi continuously getting prompted for resetting the password, and setting and answering a couple of security questions. Tri...
5cubajoe
Apr 07, 2022Aspirant
Did you ever get this figured out? I'm having the same issue and it's frustrating. pooruser
pooruser
These are the few steps that we performed. Not sure, which one helped
- Hard reset the router (by using a paperclip and pressing the reset button for 30 sec)
- This might have removed the cache and might have triggered the firmware update.
- After the router came back online, we tried to connect to wifi in mac. (By clicking on the wifi icon in the header).
- This step will trigger a password reset pop up. It will be little different than what you see in the browser.
- We entered the new password + answered the security questions
- Instead of clicking on the "Next" button, this time, we clicked on the > icon in the status bar (bottom of the popup)
- We did not see any error page, but saw the success page and that changed the password for all devices.
- Now, when we try to connect to wifi on tv or phone, it did not show the reset pop up
Hope this helps!
- 5cubajoeApr 08, 2022AspirantNot sure what helped but my biggest issue was getting the login screen to work with “modern” browsers. I think when I ran 192.168.0.1 on actual IE that I finally got it to work. Who knows, but I don’t have to replace it.
