Meimeiz1
Jun 27, 2022Tutor
C6900 upstream light blinking
Hello, the upstream light is blinking, is that normal? If not, how to fix it. thank you!
- Jul 06, 2022
here's how to get the event logs:
Check your cable and make sure there isn't any splitters. Technically your power levels are in spec and you don't have errors but you're borderline and the upstream might have more resistance causing it to not lock enough channels.
Jun 28, 2022Guru - Experienced User
Whats your downstream and your event logs look like?
Meimeiz1
Jul 06, 2022Tutor
Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- Meimeiz1Jul 06, 2022Tutor
I am not sure how to get event logs.
Thank you!
