Meimeiz1
Jun 26, 2022Tutor
C6900 upstream light blinking
Hello, the upstream light is blinking, is that normal? If not, how to fix it. thank you!
- Jul 06, 2022
here's how to get the event logs:
Check your cable and make sure there isn't any splitters. Technically your power levels are in spec and you don't have errors but you're borderline and the upstream might have more resistance causing it to not lock enough channels.
Jul 06, 2022Guru - Experienced User
Meimeiz1
Jul 06, 2022Tutor
Thank you very much! I had an Xfinity technician came over, he fixed the problem for me. It was a hidden splitter in the wall.
