GlobalGrl327
Sep 23, 2021Follower
C6900 with nighthawk mesh system
can someone please help me and confirm that I can use the netgear nighthawk wifi6 mesh system, even though I have he netgear (combo modem/router) c6900? Is there a trick to using the nighthawk as the...
michaelkenward
Sep 24, 2021Guru - Experienced User
What Mesh system do you have in mind?
GlobalGrl327 wrote:
Is there a trick to using the nighthawk as the router please, or once I plug in it should be good to go?
You do not want to have two routers on your network. It can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router. Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
A lot of people use an Orbi system in AP mode, especially if they have a decent router in front of it. Only you know which of your two routers provides the best features for your needs.
