GlobalGrl327
Sep 23, 2021Follower
C6900 with nighthawk mesh system
can someone please help me and confirm that I can use the netgear nighthawk wifi6 mesh system, even though I have he netgear (combo modem/router) c6900? Is there a trick to using the nighthawk as the...
michaelkenward
Sep 24, 2021Guru - Experienced User
FURRYe38 wrote:
However, when you look at the modems web pages you may not see bridge mode. You may See Router mode = Yes or No on some modem UIs.
That is why I checked the manual and provided a link to the appropriate section in that. In this way the user did not have to dig around looking for "modem mode" or "modem only mode", phrases that are not in the manual.
When dealing with questions like this, I put myself in the user's shoes and try to remove any unexplained specialist jargon. It reduces the likelihood that they will have to come back later with more questions.
It is not what I know that matters, but what the user may not know.
Sounds good. Please tag in the user instead of me then. I'm already aware and of course with try to be more detailed when I can.
Thank you.
