stheobald
Aug 27, 2019Aspirant
C7000 – Nighthawk AC1900 WiFi Cable Modem Router - does it support POE?
Does anyone know if the C7000 – Nighthawk AC1900 WiFi Cable Modem Router supports POE? I have a work VoIP phone I would like to use and it doesn't have a power adaptor as we have POE at work. Thank...
Aug 27, 2019Guru - Experienced User
C or CM series modems don't support POE. POE is mosly found on LAN switches for those that do support POE.
Please review any NG C series modem information in this forum:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Good Luck.
