FrostyDaCodeman
Nov 17, 2019Tutor
C7000 – Nighthawk AC1900 WiFi Cable Modem Router- Red Blinking Power Light
Noticed Alexa wasn't connected to the internet and checked the Router to find a blinking red power light. First, I unplugged the power for about a minute but it continued when I plugged it back in. T...
- Nov 19, 2019
But its within warranty which is good. Usually the symptom you're having is hardware failure or firmware failure and with the C7000, the user isnt able to replace the firmware. Let us know how it goes!
Nov 18, 2019Guru - Experienced User
Many people just hit the reset button. it needs to be pushed and held. Try disconnecting the coax again, while its powered on, push and hold rest until the lights change. its usually 7-10 seconds.
If this causes the ligths to change, give it time to fully boot up. Then reconnect the coax.
If this didn't work, you can possibly try a 30/30/30 reset. What that is is to hold the reset for 30 seconds with it powered up, while still holding reset, power it down for 30 seconds, then while still holding reset power it back on for 30 seconds. Then give it a couple minutes to see if it boots up all the way.
Are any of the other led's doing anything?
With a router we'd be able to walk you through a tftp recovery but it doesn't work for combo devices.
FrostyDaCodeman
Nov 18, 2019Tutor
Thanks for the suggestions. Tried both of the suggested reset processes but to no avail. While the power is plugged in the blinking red power light never turns off as I would expect from a reset. No other LED's light up. Tried also plugging directly in with ethernet but nothing was recognized.
- plemansNov 18, 2019Guru - Experienced User
You put that your "premium support" ended. Is it still within warranty? Different area's have different length warranties based on region.
- FrostyDaCodemanNov 18, 2019Tutor
After registering it looks like the hardware is the only thing still in the warranty period. I'll have to call tomorrow and see if they can help me out.
- plemansNov 19, 2019Guru - Experienced User
