FrostyDaCodeman
Nov 17, 2019Tutor
C7000 – Nighthawk AC1900 WiFi Cable Modem Router- Red Blinking Power Light
Noticed Alexa wasn't connected to the internet and checked the Router to find a blinking red power light. First, I unplugged the power for about a minute but it continued when I plugged it back in. T...
- Nov 19, 2019
But its within warranty which is good. Usually the symptom you're having is hardware failure or firmware failure and with the C7000, the user isnt able to replace the firmware. Let us know how it goes!
FrostyDaCodeman
Nov 18, 2019Tutor
Thanks for the suggestions. Tried both of the suggested reset processes but to no avail. While the power is plugged in the blinking red power light never turns off as I would expect from a reset. No other LED's light up. Tried also plugging directly in with ethernet but nothing was recognized.
Nov 18, 2019Guru - Experienced User
You put that your "premium support" ended. Is it still within warranty? Different area's have different length warranties based on region.
