FrostyDaCodeman
Nov 17, 2019Tutor
C7000 – Nighthawk AC1900 WiFi Cable Modem Router- Red Blinking Power Light
Noticed Alexa wasn't connected to the internet and checked the Router to find a blinking red power light. First, I unplugged the power for about a minute but it continued when I plugged it back in. T...
- Nov 19, 2019
But its within warranty which is good. Usually the symptom you're having is hardware failure or firmware failure and with the C7000, the user isnt able to replace the firmware. Let us know how it goes!
FrostyDaCodeman
Nov 18, 2019Tutor
After registering it looks like the hardware is the only thing still in the warranty period. I'll have to call tomorrow and see if they can help me out.
Nov 19, 2019Guru - Experienced User
- michaelkenwardNov 19, 2019Guru - Experienced User
It certainly sounds like hardware failure to me.
- FrostyDaCodemanNov 19, 2019Tutor
Called support and they issued a replacement device. Thanks for all of the help!
