WJScott66
Sep 18, 2019Aspirant
C7000-100NAS - Static Route
I need to establsih static routes on the Netgear to allow routing of traffic from it to a numer of VLANs/setments within my home lab. These are hosted behind a NSX Router/Firewall with gateways to ea...
Sep 18, 2019Guru - Experienced User
If you dont' find any information regarding static routes for the modem, then that feature may not be supported. You would need to bridge the modem and attached a different external router like one of NGs R series routers that should support static routes.
