Drew2
Mar 07, 2016Star
c7000-100nas Internet sync problems
Purchased a C7000 about a month and a half ago. Occasionally the Internet will go out but I can usually reconnect by disconnecting power to the modem and rebooting. However on two occasions the mo...
MooseMan347
Aug 08, 2016Guide
Not to worry JMS28411 These Critical errors are relative to the Time Warner equipment at your location. Check the MAC addresses against those in your Equipment identified on https://myservices.timewarnercable.com/myservices/internet/index (you must be logged in first).
I reboot my Netgear perhaps once per month but it is most often because TWC is jacked-up. There is never an explanation.
I love the Netgear, the jury is still out on TWC though. I love the speed from TWC. I get 235mbps consistently while paying for 200mbps. The modem you use will directly dictate your network/TV performance. The Netgear Nighthawk has 24-bands whereas most others are perhaps 8-bands. Give it some time.
JMS28411
Aug 08, 2016Aspirant
Right now I have three PC's, a laptop two cell phones and netflix running with no noticeable problems :)
I guess I will see what happens over the next 2 or 3 weeks.
I also picked unused channels for my 2.4 & 5 g channels
- JMS28411Aug 12, 2016Aspirant
I seem to be having trouble connecting to some web sites, I have to refresh the website link 2 or 3 times to get it to connect, might be TW cable not the C7000 nighthawk?
- MooseMan347Aug 12, 2016Guide
JMS28411 - Is the site refresh issue true for both WIFI and Ethernet? I don't seem to have this issue unless my connectivity is out for all devices. This rarely occurs, but when it does, I power-cycle the Netgear router which usually resolves this issue. If this doesn't work, I recycle the TWC cable modem device (I have VOIP with TWC which uses the ARRIS MTA which I have powered off, since I don't use it.)
- JMS28411Aug 13, 2016Aspirant
I was having a problem on wired connection, not a consistant problem, but enough to be annoying :(
