Drew2
Mar 07, 2016Star
c7000-100nas Internet sync problems
Purchased a C7000 about a month and a half ago. Occasionally the Internet will go out but I can usually reconnect by disconnecting power to the modem and rebooting. However on two occasions the mo...
JMS28411
Aug 08, 2016Aspirant
Right now I have three PC's, a laptop two cell phones and netflix running with no noticeable problems :)
I guess I will see what happens over the next 2 or 3 weeks.
I also picked unused channels for my 2.4 & 5 g channels
JMS28411
Aug 12, 2016Aspirant
I seem to be having trouble connecting to some web sites, I have to refresh the website link 2 or 3 times to get it to connect, might be TW cable not the C7000 nighthawk?
- MooseMan347Aug 12, 2016Guide
JMS28411 - Is the site refresh issue true for both WIFI and Ethernet? I don't seem to have this issue unless my connectivity is out for all devices. This rarely occurs, but when it does, I power-cycle the Netgear router which usually resolves this issue. If this doesn't work, I recycle the TWC cable modem device (I have VOIP with TWC which uses the ARRIS MTA which I have powered off, since I don't use it.)
- JMS28411Aug 13, 2016Aspirant
I was having a problem on wired connection, not a consistant problem, but enough to be annoying :(
