Drew2
Mar 07, 2016Star
c7000-100nas Internet sync problems
Purchased a C7000 about a month and a half ago. Occasionally the Internet will go out but I can usually reconnect by disconnecting power to the modem and rebooting. However on two occasions the mo...
MooseMan347
Aug 12, 2016Guide
JMS28411 - Is the site refresh issue true for both WIFI and Ethernet? I don't seem to have this issue unless my connectivity is out for all devices. This rarely occurs, but when it does, I power-cycle the Netgear router which usually resolves this issue. If this doesn't work, I recycle the TWC cable modem device (I have VOIP with TWC which uses the ARRIS MTA which I have powered off, since I don't use it.)
JMS28411
Aug 13, 2016Aspirant
I was having a problem on wired connection, not a consistant problem, but enough to be annoying :(
